My Navigation system was not connecting to Wi-Fi, after much effort I had to reset it and it worked but ever since reset the Tracking world Navigation is missing. I can't find it anywhere in device. How to get it back?
Contact dealership for maps issue.
Never reset the system. Only set the sleep time to 1 HR. The player will keep rebooting often and things like wifi and bluetooth will keep working fine
Thanks, it helped!!
Uploading... Anyone got remedy for this?stuck here
go to file manager, under SD u shall find folder for installer with apk for tracking world.
I am facing the same issue. My navigation is working fine but wifi is not working. I havent reset the system yet. Is there any solution to get the wifi working?
I am facing similar problem. My navigation is working fine but wifi is not working. I havent reset the system yet. Is there any solution to get the wifi working?
The reset button is with sd card slot. Use pointed object to press it. Things will be fine
don't reset the system. Only set the sleep time to 1 HR. The player will keep rebooting often and things like wifi and bluetooth will keep working fine
i also did the same. and ended up clearing maps didn't found any solution and in last fortunately dvd got stuck and i got player changed under warranty and new player have maps now
regarding wifi issue . i have faced this issue many times but it gets fine itself within some days. so have patience it will get fine
i never had issue ever since i set it to sleep in 1 hour.
maps apk is available in file manager. one can reinstall it if they some how remove it.
I never find in system second one whats is backUp restore Password i have see only this option new install from file they ask me sd card not find my civic is 2017 model thanks
Did you got any solution same issue i'm facing right now
