hi
Okay I found the Gaskit from Mehran Autoz Sadar Rawalpindi for PKR 1500 and it was made of some kinda sheet and not rubber but it fits and installs perfectly. Reading all the thread, I am slightly skeptical to follow which of two procedures for Engine Transmission Oil Filling. If any one can guide me. Its urgent coz tomorow I have to fill the Engine Transmission Oil myself as my car is parked in Garage.
First Procedure from TC Nut (Big Nut)
- Open Sump Drain Nut at the bottom of Chamber Cover
- Install the Plastic long tube
- Open TC Nut
- Fill the Oil till it drains from the Sump nut Drain
- When oil drains, close the Sump Nut
- Close the TC Nut
Second Procedure Oil Filler Port
- Drain out all the oil (the old one)
- Install the plastic tube and Sump Nut Drain
- Open Oil Filler Port
- Charge oil from Oil Filler Port till it levels off
- Close the Oil Filler Port
Any body with any suggestion. Well to inform you, Toyota Motors at F-15/2 performed the first porcedure for oil filling which should I adopt. I assume the Sump Oil Drain Nut at the Cover of Engine Transmission Oil Chamber must be closed before filling the oil from Oil Filler Port.
Please explain
Thank you
