Is their any other better option for honda city transmission oil other then the total honda transmission oil
Only use Honda recommended ATF oil
Their must be any alternative
There is none - the only real option for this fancy manual transmission with a torque converter is Honda's own DW1.
Multi type ATF doesnt work because the design is much different than a conventional planetary gearset automatic.
Thanks
So you’re saying every honda vehicle with a Prosmatec transmission is actually a manual transmission with a torque converter on it.
That was a crude way of putting it, but yes - the design is closer to a manual transmission than a traditional automatic i.e. one that uses a planetary gearset.
