Can transmission unit of car be repaired ?
What is the problem with it? Broken casing is replaced and any part damaged is replaced.
which car make variant & model in Pakistan transmission swap from scray yard is more economical then repairing it.
when swapping transmission make sure you drain the fluid & top it with fresh one.
Gear shifts problem only in winter...I have mini pajero 1995 4x4 3 speed auto...In winters it is locked on 3 gear and doesnt downshift but in summer it works properly
you may need to connect the transmission cooler lines with radiator bottom tank as original setup.
I just wanted to know that can transmission unit be repaired
no transmission can not be repaired. It can be cannabalized
