trying to do a quick delivery??:o
how would you solve this problem?
//youtu.be//watch?v=iwXqWt6FsJY&feature=related
lift those jack type thingies
wheel is stuck between trailor and road
I know that behind the second axle there are the lift/jack shouldn't they be up ?
lift jack should be up but still wheel wont move:)
then its beyond my IQ level
Can't the trailer be unhooked? Unhook it and lift it a little by a crane.
flat out the rear tyre dat may do the job
you guys are sooooooooo smart.
comon guys, its not that difficult.
where are the pw cheetas?
put some slabs or bricks in front of the rotating wheels...
Well I think the truck doesn't have a power divider in it's rear axles because both the rear set of wheels don't seem to spin together. I think the best way out of this situation would be to try the good old brick-under-the-wheels method so that the wheels that are actually spinning get some traction and manageable ground clearance.
In such cases, if trucker or company uses a GPS tracker or especially a reliable ELD device https://bestelddevices.com/best-eld-guide/ then it is very easy to get help to fix the issue or even you can avoid such accidents as well. However, government must introduce ELD or GPS systems for truckers that should be approved the transportation department before use. In this way, we can avoid a number of daily accidents.
