have your Hybrid system checked for health, spark plugs and coils on these engines are usually a 150,000 to 200,000 kms job as the engine isnt used as much.
Also make sure you are using the correct engine lube as a thick one can rob a lot of engine power and increase your fuel consumption.
Final check is to make sure your exhaust system is in good health, Do not fall for the "catalytic converter hydrogen cleaning scam jobs that are plenty in Pakistan" - The cat is self cleaning and its efficiency can be checked from the scan tool and a portable propane cylinder.
Another issue is that the fuel consumption of these prius/aqua is not stellar on highways. These cars give their best in city only.
