I am very much excited to read this,first of all i would like to say thanks to @atta1111 to tag me here
The anti lag can be ONLY done with an aftermarket ECU, also we can do it with Unichip.
I will try to explain the system in simple words,
First there should be a clutch switch which tell your ECU or Unichip that now the anti lag should work when the peddle is depressed.
What happens is that we retard the timing to such a level with adding required fuel amount the the car will make more boost on low rpm (this is the point a tuner can set how much boost at this level should be achieved ) but as explained by many fellow friends that make VERY high EGT and you MUST have a good turbo manifold and a turbo to hold this temp.
As soon as you release the clutch the Ecu or Unichip will switch the ignition timing and fuel to normal values and you will make massive power at the start. ( this also need a good track traction ) if you are using for drag otherwise you are going to waste all this in the wheel spin.
Regards
Yasir
