A wastegate is a valve that controls the flow of exhaust gas to the turbine of a turbocharger.
The wastegate’s job is to divert excess exhaust gases away from the turbine – controlling the speed of the turbine and preventing it from spinning too fast.
By controlling and limiting the speed of the turbine, the wastegate regulates the boost pressure provided by the turbocharger. By preventing the boost pressure from rising indefinitely, the wastegate protects the turbocharger and the engine from damage.
In most cases, a wastegate is a relatively simple valve, controlled by a pressure actuator linked to the boost pressure of the turbo.
The wastegate is held shut by a spring inside the actuator, but when the boost pressure exceeds the pre-set maximum, it compresses this spring, progressively opening the wastegate. This allows the exhaust gases through, so that they bypass the turbine, regulating its speed.
Different kinds of wastegate
There are two main types of wastegate, which both work in slightly different ways:
Internal wastegates
Most turbochargers are fitted with internal wastegates, with a valve that is built into the turbine housing itself.
This valve is controlled by an actuator, which consists of a spring and a sealed chamber, and this chamber is linked to boost pressure (usually via a pressure source found on the compressor cover of the turbocharger).
External wastegates
Usually reserved for higher power engines fitted to performance and race vehicles, external wastegates are separate, self-contained mechanisms that are usually fitted to the exhaust manifold or header.
External wastegates feature larger inlets and outlets, higher pressure springs and larger actuator diaphragms, so that they can effectively handle higher boost pressures.
Things to consider
Performance and tuning
Whilst perfectly sufficient for the vast majority of motorists, internal wastegates are only designed to handle the performance of a turbocharger at stock boost levels.
If you are a performance enthusiast looking to modify your engine and maximise performance, it’s important that you have a wastegate that’s correctly sized for your turbocharger to prevent damage.
If you’re fitting an aftermarket turbo, you may need to invest in an external wastegate to effectively control the additional boost and power (and many larger aftermarket turbochargers aren’t fitted with internal wastegates anyway).
