The turbo on my Suzuki Jimny seems to be making chirping, whistling noises at the beginning of its boost range, at around 0 - 2 psi. It's an IHI RHB31 turbo with a VZ9 housing.
It does not make any noise apart from the normal spooling sound after 2 psi, develops 10psi under WOT, 7-9psi under moderate to heavy load. It behaves completely normally otherwise. I have a BOV installed instead of a diverter/recirc valve.
I suspect it might be a gasket seal failure on either the intake or exhaust side of the compressor, vibrating and causing it to behave like a reed. Or is my turbo close to failure?
