When looking after your tyres one thing you will always need to keep an eye on is the air pressure level.
Under-inflated tyres will wear in such a manner that they become unusable and susceptible to a blowout early in their use.
FuelPump-1
Fuel consumption is affected by tyre pressure and can be decreased by ensuring that the level is always at an optimum level.
If your tyres suffer from low air pressure, the wear on the tread will increase, causing an increase in the amount of fuel used.
A change in temperature will can affect the pressure of a tyre. For this reason, you should check them on a regular basis, especially when the seasons are changing.
The proper air pressure should be recorded in your operator?s manual, or a notebook where it can be easily referred to.
Tyre manufacturers recommend measuring the tyre pressure at least once a month and rotating your tyres on a regular basis.
