i have the same profile on vitz, it doesnt touch anything on full turn.
ideally if the issue with thickness/profile of the tyre than it should touch both sides i.e. right and left
if its touching only left than firstly check the alignment of the car and 2ndly check if the protective plastic sheets is not loose at the left. your tyre is probably touching the loose sheet and not the body of the car.
