guyz i wanna change the tyres currently running on my vitz..what would b the suitable size??...iam thinking to go for 185/60/r15...is that ok??..and which tyres should i go for??
bumpy the bump..
koi to bta do....
new shape vitz is kind of underpowered and does not do wonders in fuel consumptionits better to stick to stock rim size and not to wide tyres
Either 185/60/R14 or 195/60/R15.
Also, if ur going for size 15", you would have to incur the cost of rims too, keep that in mind. 185/60/R14 would just be fitting your current stepnys, however I should tell you that sticking to size 14 would not make that much of a difference.
R15 ll definatly improve look of your ride but ll ultimatly ruin suspension.my suggestion stick to stock size
i changed the tyre size to 195/65/r15...
gud upload pics
195-65-15 and no problem since two years , and 65 profile gives a little height too the car as well , plus the original profile was 70 in 14 rim size , 65 is same height as the original.
165/70/R14 the best profile.
Don't go for 15's, the maximum you can go without damaging your suspension and ruining your fuel average is 190/75/R14.
for best performance get the stock tire and rim size.
if i go 4 the best profile that u mentioned will i still need to add some padding to solve the low ground clearance prob ?? if no then what wud b the best option in order to get max fuel efficiency ?? standard tyre R13 with padding or wat u hv mentioned ??
