please share if car is running on direct fans & plain tap water in the radiator without thermostat in system. -
if SO - get a new 82 C ( 88 C ) thermostat valve [ common on PKDM Suzuki Vehicles ], flush the cooling system, put T/S valve in system, rewire fans to work on automatic & if required retard a bit ignition timing using timing light
@mzahid
Thank you @margallar for thermostat specs, suzuki Ravi & Bolan have 88 C valve
