You have a deep insight Yasir Sb.
Previously when the bike was on stock engine (CD185) 184cc 17HP and I used this Tyre there was a marginal loos in initial acceleration and also bad braking as it was to hard to stop a mighty wheel rotating.
so If you notice my previous posts I also bought a new engine (253FMM (234cc) which comes in 4 flavors - 16.1hp - 18.5 hp tuned down - 20BHP in single carb and 22BHP in Dual Carb model) I bought the 22BHp version 1997 model
This engine appears in multiple Honda Bikes including NightHawk CB250, CMX250, CM250 Rebel, CA250, and ATVs its called a virtually bullet proof engine, in stock rebel this engine pulls a 130/90 - 15 or 120/90 - 16 and I am using 140 / 90 - 15 so that I will not loose any acceleration as its as tiny as 15' inches and also give soft drive as its a 90cm cushion, I only increased the width of the tire to have better road grip, If I had increases the cushion from 90 to 100 or if I have installed a bigger RIM like 16 or may be 17 then it would have killed the acceleration so I choosed the same specs as original only increase the width of tyre. Let hope for the better
