Thank you Xulfiqar for being a part of this thread.....
I have got almost every thing that you have mentioned above.
1. ABS model MC
- Yes, but the size is 7/8", available sizes are 13/16", 14/16", 15/16" and 16/16", should I go with it or I have to use a bigger size MC.
2. Proportioning valve - Yes, but its for the non abs model (this is what i think as it has got 6 ports). If I am unable to find 4 port ABS prop valve, I will run the two rear wheel pipes straight in to the wheels. The proper prop valve will be inserted later on if I got one.
3. ABS pump
- Yes
4. ABS computer or control unit
-Yes
5. All Complete 4 wheels hub assembly with tone ring, sensor with pigtail wire
- I haven't got them right now but they are available easily
6. Piping
- Piping will be arranged by the mechanic who will fit the ABS
7. ABS Fuse/Relay Box
- Yes
8. Wiring Diagram
- Available
ABS pump module Pic 1/2
ABS pump module Pic 2/2
Prop Valve (6 ports)
Brake booster with 7/8" MC Pic 1/2
Brake booster with 7/8" MC Pic 2/2
ABS computer Pic 1/3
ABS computer Pic 2/3
ABS computer Pic 3/3
ABS Fuse/Relay Box
ABS wiring diagram Pic 1/2
ABS wiring diagram Pic 2/2
Regards
