I mistyped it .. there are no magic ingredient, and it also dont have Friction additives which are bad for wet clutch but are good for Car engines which dont have Wet Clutch and those additives eat the wet Clutch as its there job to eat and reduce the friction ...
So bike works fine, as your bike is running fine as well (new off coarse) but its Clutch will die soon if you keep on using a oil which contains friction additives...
about Rotella 'T' not all rotellas as in same forum then mentioned other Rotella failed the test... if Rotella T has passed JASO test then it can be used in Bike and they will sure print JASO MA certification logo on it... and as by the book we all can use it...
its about understanding your bikes engine... you cant feed a toddler with Seekh kabab he may digest few time but then he will sure get food poisioning soon u know... same goes to bikes.. I am not sure and have not explored Deisal oils if they dont have any additives which may harm wet Clutch bikes then it might be useable...
but offcourse I am not pro in this so I stay by the Book
