In 4 stroke motor bikes JASO specs(Japanese standard) should be followed. Please find below the explanation,
Modern passenger car engine oils contain more and more friction modifiers. While this is the good thing for those segments (reduces wear and fuel consumption) it's bad for the motorcycles. At least for those motorcycles which use engine oil to lubricate their transmission and wet clutch. JASO introduced the MA and MB specification to distinguish between friction modified and non friction modified engine oils. Most four-stroke motorcycles with wet clutches need a JASO MA oil.
JASO MA
Japanese standard for special oil which can be used in 4-stroke motorcycle engine with one oil system for engine, gearbox and wet clutch system. Fluid is non-friction modified.
JASO MB
MB grade oils are classified as the lowest friction oils among motorcycle four-cycle oils. Not to be used where a JASO MA grade oil is required
Suggest to buy any motorcycle oil on which JASO specs is written.
