Most of us know how the injectors get clogged. Its nothing else but the fuel that we use which causes clogging. Every time we turn off our car's engine, last drop of petrol dries on the nozzle of the injector and leaves behind deposits. These deposits become firm with the heat of the chamber. The more we drive our car, more deposits accumulate. Gradually it starts to restrict the flow of petrol from the tiny hole on the nozzle and the injector starts to lose its efficiency. This causes the engine to lean misfire and hesitate on different rpm, power and pickup is lost, the car becomes uneconomical on petrol, unburnt fuel can be noticed in the emission and worst of all the wear of engine becomes faster. Only 8% to 10 % clogging in the nozzle can cause all this
Proper cleaning can restore their like-new performance. There is no need to replace fuel injectors unless they are actually gone bad. Injectors are designed in such a way that they are not very convenient to clean. They are sealed units and cannot be opened for cleaning. Ultrasonic cleaning is internationally accepted MOST effective process for cleaning fuel injectors. It is cheap and comprehensive solution for the problem.
In ultrasonic cleaning, the injectors are removed from the vehicle, tested for symmetry of flow and spray pattern on the test bench. The statistics are noted on a sheet. The injectors are then cleaned ultrasonically after which they are once again tested for the rectification and finally mounted back to the engine. This process eliminates missing, rough idling and hesitation. It restores power, improves economy, emission and generally enhances the performance of the engine by improving flow of the fuel.
