If engine is out and ustaad is working let him finish. Make sure to install thermostat valve into system. Start the car and move out.
Never return to this shop again.
Connect fans to work automatic, flush radiator and add caltex coolant.
Use only 5w-30 grade engine oil for rest of the time you keep this vehicle.
Locate a workshop which can work under your instructions. You have an edge of reading & Understanding english. And you are member of this forum
Good luck
