By fitting discs which are the same exact size (diameter) as your current ones you will not gain any braking efficiency but your cars brakes will become more resistant to brake fade due to improved cooling.
If you want better brakig you'll have to change the composition of your pads and/or discs. alternatively you can fit larger diameter discs and have the calipers moved which will give the brakes more leverage, but since the contact patch will be the same as before the brakes will not be 100% efficient.
For ideal braking you should try to get brakes from a higher model of your car.
