Aoa. I have cultus 2010. My car starts vibrating on 80 km/hr speed. When it goes above or down from this speed the vibration also stops. What may be the reason? Thanks
It can be either one of the following..1. An out of balance tyre/ rim2. A bent rim3. A misaligned axle4. A deformed tyre5. A broken or weak engine or gearbox mount6. A Suspension in need of alignment
Thanx for ur reply. Where should i start from? Should i check wheels alignment first?
Your alignment shop should be your first stop. 4 out of 6 things will be sorted out there.
Yeah that's what I've been thinking. Thanx for ur help
