Bhai,
My company has experience in installing all these Vinyls, semi solid, laminate and solid wood floors in some of the exclusive places on earth. And we have used Vinyl products from across the globe, from Amtico to Karndean. So as per my experience, I am telling you how its properly done. Now if you are moving frequently, still you wont be able to use same flooring. While lifting it, regardless of laminate or vinyl, the interlocking gets damage. Hence you cant use it again. With Glued Vinyl, you dont even need skirting. Its optional since PVC does not expands with weather changes. But with laminate you must have skirting because while installing, you need to leave a 3-5mm gap between wall and flooring so that while it expands, floor wont pop out.
