no need to worry guys here
@mrh20001: its not like this....plus you are breaking the hearts of thousands of vitz owners. I own one and know 2 close friends who do too...mine is 2006 and 78k done,...it gives 16 kmpl in city with low AC and 21.7 kmpl on highways with full AC...the looks of the car, its quality of material, its strength, its engine and consumption all are par excellence...(and same is the case with my friends cars)
@hashims: CAT can be cleaned. Just get it opened, place it in open vertically and spill few drops of water diluted sweep(toilet cleaner) in its centre with a teaspoon etc...let the sweep drain from its bottom. repeat the process 10-15 times and you will see that the sweep will drain out upto 80% of the dirt. Just make sure the sweep doesnt touch the side walls as they are made of foam and will melt away
@midnight vulture: from what i can assess, you are pressing your throttle too hard. the avg is bound to drop. maintainence is also an issue, please gets new spark plugs from JZ Awan, get oils/fluids changed, see if your tires are the ones specified by the factory. get good quality petrol from a trusted pump. also get fuel pump cleaned from a mechanic. and your vitz will rock. Just remember its a 1000 cc economy car, dont expect it to run like a ferrari. a soft foot on throttle will do wonders!
