We've had good hands over these performance engines Never ever use this type of maf meter or housing... Always use genuine maf housing for Toyota afm because improper protrusion of af sensor destroys afr infact it drops the performance aswell.
First it needs afm housing, which you can only get in saddar on top of madina market in mithu khan, which is also a chance... As 2zz uses thicker intake pipe size.
Second thing is when it looses compression to 130-140's economy drops slightly. So after hooking good scantool the live values need to be overlooked. And the illiterate efi goons don't have any clue of live values.
Second thing which I'm sure is 2zzge a/t ecu would have been used with this.
So start with compression, don't get anything done on wiring before gathering any live values, compression test results...
