i have a vitz 2003 its perfect on CNG pick is smooth shifting is normal, but when i start on petrol its missing on low speed which i give speed speed acclerator is normal but when at after 45 its change gear it give high acceleration sound and change the gear but on CNG shifting in normal. i have change the plugs and 3 injectors but the problem is same
problem in valves if cng is used extensively! valve stem or whatever is needed to be grinded! this is the exact problem which came in my 2008 xli.
they are called shims to be exact!
cooldevil how much money needed for this process
i think i good mechanic will not take more than 10k!
only in idle position its missing acceleration in normal till 45 to 50 after that is it give acceleration sound and change the gear car driving is fine
yes the problem arises from initial! later ur car will take a longer self to get started on petrol and the missing will gradually increase
i need one more advise i want to switch to honda civic vti oriel prosmatic 2002 to 2005 model is that car performance good on cng what abt engine and transmission life on CNG
If its giving you trouble on petrol only, it is possible that your cars fuel system, filters, pump, injectors might have issues.
need more suggestions
