AoA,My Vitz 2003 have wobbling problem at low speed (up to 10-15 KM/h). I have changed the front chimptas and shocks, wheel alignment and balancing done but no success. The wobbling is more visible when I am alone in the car. The wheel balancer guy told me that you will need to change the tires. He changes the one tyre that was a little bent but no success. Suggest me what to do. should I change all the tyres or change the back hissa ?
Check axles aka godey and mounts also. And replace tyres with new ones if they are bent.
Are the wheels in proper shapes; an out of shape wheels and tire are prime source of odd wobble
Definitely get this checked. Most of the times its usually the tire alignment that causes the wheel wobble.
change tires if they are deshaped change rims if they are bent
I have changed tires, rims, shocks,one left side wheel baring, checked the axels, steering box but the issue still exists
I have the wobbling 30 -35 kmph and 80-85 kmph and i also done same things and even change axels...butvthe problem is still there....now whats the status of wobbling? Koi hal nikla?
