Don't want to get into a argument just having a discussion, I think you should go through the tree headings your posted yourself
You haven't yet put forward single, source proving any of your claims let alone anything substantial to counter Xulfiqar's view in the link I provided
Giving example of gulf countries doesn't prove anything, and even that argument is flawed as if as you say in every country minimum two octane fuels are used then why does it matter if your car is JDM or not or people are worried that their car knocks on fuel here, a car which requires premium will always have a sticker on the fuel filler flap saying so and your vitz doesn't require premium, the only reason it knocks on normal petrol here is because there is a difference in every countries octane rating and quality of fuel and your car is species for japanese fuel which uses different addictives than the formula here
You should read through all above headings and then do a scientific test
I have a gli which is Euro 2 so catalytic converter and has same compression ratio as your vitz which is 10.5:1 and its manual also says to use 91 Ron if I am not mistaken
I did a detonation test with the car moving and a diagnostic reader connected
On normal pso petrol it reported no to slight detonation/pinging
On 50/50 it reported no detonations
And I have tried 100% hi octane too in my Altis with a compression ratio of 9.5:1 which doesn't require hi octane and the diagnostic reader showed a very slight increase in calculated engine load as it would have found it harder to burn of fuel but I didn't notice any difference in drive with either 50-50 or pure 100% anyway
Mercedes does not reccomends any petrol addictives in the manual and I only used it once in 6 months when hi octane was in shortage, but i would trust it more if I had to then to fill up hi octane in a petrol pump rather than filling up form a pump I haven't tested wih the other car let alone 100% HOBC
provide any proof to your claims otherwise your arguments aren't substantiated and I am least budged, we have detracked from the thread anyway, the only reason I posted about it initially is its a common misconception and I have personally seen more people In my community use it because they are under a misconception that thier car require pure HOBC or they think it's cool because they equate it akin to people filling up their hi compression direct fuel injected latest Mercedes
Sent from my iPhone 6Plus using PW Forums
