As you said you had tried every battery so...
1: check the generator whether it is charging your batt properly.
2: Check the wiring, there might be some battery utilization as i had experinced the same. My case was that the dec light remained on while i close the dec and switched off the car, so after a day or so, while i didnt use the car, the batt gets dead... so check out that factor as well.
