Got following list of items for overhaul (estimated items)
- Piston Set (0.25 or 0.50 depends upon head condition)
- Ring Set
- Valve Guide
- Valve Set
- Valve Seal Set
- Main Bearings
- Thrust Washers
- Oil Pump
- Water Pump
- Engine Seal Set
- Jane Kit (I am not sure what is this)
- Timing Chain
- Timing Chain Adjuster
- Fan Belt
- Engine Foundation
Estimated Cost for above Japanese parts: from 32000 to 35000 PKR
Japanese Brands for Auto Parts: NPR, RAK, Toyota
- Engine Head Boring Labor = 7000 PKR
- Mechanic Labor = 8000 PKR
- Transmission Oil + Engine Oil estimate = 5000 PKR
- Exhaust Catalytic Converter (used estimated) = 5000 PRK
Sub Total for Parts (estimated) = 32000 PKR
Sub Total for 16 to 19 (almost confirmed) = 25000 PKR
Total = 55000 to 60000 PKR
Which made me confused to rethink about overhaul vs Kabli Head Assembly Swap
Experts advice required to re-assess above list specially from 1 to 15.
