Problem: Engine Turn Off when press a brake during driving
Causes:
1. Idle air control valve (IACV Valve) jammed
2. MAF sensor
3. Brake booster vacuum lines
4. Check ignition timing
5. Fuel pump wiring issue; blow the EFI fuse
6. Perform compression test and check engine health it will not take load on slow speed
