Aoa, I have a Vitz 2009 1KR-FE. I changed its transmission oil around 7000km ago.
Yesterday I had to go Gujranwala from Lahore. I was running late so I drove quite aggressively. I used to shift in S when I wanted to accelerate quickly or overtake. I reached Gujranwala and the car was fine.
On the way back I was cruising at 70 km/h in D and the check engine light (CEL) turned on. Upon reaching home, I disconnected the negative terminal to reset ecu. In the morning the CEL was off, but after 10 mins it turned on again.
Now the CEL is ON but it turns off for a few minutes and then comes on again. Interestingly when I drive in D, the cars is responsing quite aggressively (like it does in S). When I drive in S the car is driving normally (like it does in D).
What could be the problem and possible solution?
@capsat sorry for bothering you time and again but I get quick response from you
