Guys
My vitz original key is not funtional. I visited to key maker and initially he said there was a memory issue and have to be replaced but once ready for programming he said key is OK and responding but car is not responsive. He said there could be two issues.
1. the system which is installed on the back pillar has some issue.
2. Highly likely need to replace fuse.
He suggested me to find a fuse first and replace it and not to go to open system wiring as it will lead to other issues.
He also suggested if fuse ok then better go to install stealmate security system whixh has two remotes and it works well.
Can you guys please suggest me which option is workable as i want to use my original car key and also do not want to touch any wiring.
Will appreciate ur response.
Thnx
