No not the case... Inspected it myself... Every mount is perfect... Issue is affiliated with axles and inners... Other than that everything of car is 100% working..
Basically the word vibration is used in the sense of wobbly feeling... Like you have bad rims and you go on speed and you feel wobble so that same kind of behavior is present once the car is outputting power since it's a cvt transmission if you leave the foot the power output drops, shaking disappears you again floor it, power output increases on wheels and wobble appears again...
So this is bent axle rod or bad axle inners...
