Please post a new dedicated thread as soon as Lahori soil is blessed...
Okay Ill make the list as simple as possible...
Engine bits....we can get Im quite sure. From memory some things:
A pristine 'doghouse' style fan shroud. Without any denting work done. Not necessary but if you get one not bad.
Rear pulley shield.
One engine mounting bottom stud (Ill try to source one as the original was mangled a bit).
Engine overhaul parts.....
a. Set of 1600cc piston/cylinder set.
b. Set of genuine valves and valve guides.
c. A genuine exhaust.
d. Engine rebuild gasket set.
e. New oil pump (old may be reusable)
f. New fuel pump (old may be reusable)
g. New Bosch coil.
h. New points, condensor and rotor.
i. New spark plugs and genuine wires.
j. Main and big end bearings...to be bought after the engine is dismantled.
Post 73 alternator (not essential but a good upgrade)
New clutch.
New pressure plate (the current one may be good)
New throwout bearing.
Will update with time.......
