I just came back from Cheap Autos.
Bought points, fuel filters, barrel clamp, carb's main jet(It had a crooked tip), pump nozzle and generator pulley shims.
Something interesting the Cheap guy (:)) told me:
He said that upgrading from 1500 to 1600 is not worth the power. And even if I do so, I should get used 1600cc pistons and could get away with boring the block.
And he said that dual port heads have week spark plug area, and usually theres a compression leak from there. And that DP heads won't make any noticeable power gain.
Also he said that the valves he has are imported, not made in Pakistan. I find that to be highly unlikely...
I don't buy what he says. Are old pistons trustworthy even if the ring grooves are fine?
And DP heads would provide more air in, which is good if the rest of the setup is right.
