Hi,
Been trying to resolve intermittent fluctuations in voltage in this car. The car has JDM Engine along with JDM ECU. Everything is well connected i.e., o2 is connected etc and no bypasses. No codes etc etc.
At idle the voltage at battery is around 13.9 V but at ECU its 11.8-12V. This is a significant voltage drop. I have tested grounds at ecu and it checks out. This means voltage after the fuse box is dropping. The under hood fusebox itself shows battery voltage (no drops).
To my surprise ELD is not connected. There is no connector there and ECU constantly reports 1,04A ELD PID. Strange it does not throw a code.
I am seeking hints to diagnose it and question. Did we have ELD connected in PKDM civics and can it be the reason for fluctuations?
