Thanks for reply but its not an easy test. Some one told me the vtec solenoid operates around 4000rpm, is it true? I have already checked the solenoid is functioning by giving external 12v, the problem I found that the sinal from ECU is not coming at 4000+rpm. No mechanic takes the pain to diagnose it and says dont take that tension of vtec. Can any one guide me for a competent ECU diagnostic mechanic in Pindi.
