VVT-i, or Variable Valve Timing with intelligence, is an automobile variable valve timing technology developed by Toyota, similar in performance to the BMW's VANOS. The Toyota VVT-i system replaces the Toyota VVT offered starting in 24 December 1991 on the 5-valve per cylinder 4A-GE engine. The VVT system is a 2-stage hydraulically controlled cam phasing system. The Toyota motors CEO has been reported to have said, "VVT is the heart of every modern Toyota!"<sup class="Template-Fact" title="This claim needs references to reliable sources from February 2011" style="white-space:nowrap;">[citation needed]</sup>
VVT-i, introduced in 1996, varies the timing of the intake valves by adjusting the relationship between the camshaft drive (belt, scissor-gear or chain) and intake camshaft. Engine oil pressure is applied to an actuator to adjust the camshaft position. Adjustments in the overlap time between the exhaust valve closing and intake valve opening result in improved engine efficiency.<sup id="cite_ref-0" class="reference">[1]</sup> Variants of the system, including VVTL-i, Dual VVT-i, Triple VVT-iE<sup class="Template-Fact" title="This claim needs references to reliable sources from February 2011" style="white-space:nowrap;">[citation needed]</sup>, and Valvematic, have followed.
VVTL-i (Variable Valve Timing and Lift intelligent system) is a version that can alter valve lift (and duration) as well as valve timing. In the case of the 16 valve 2ZZ-GE, the engine has 2 camshafts, one operating intake valves and one operating exhaust valves. Each camshaft has two lobes per cylinder, one low rpm lobe and one high rpm, high lift, long duration lobe. Each cylinder has two intake valves and two exhaust valves. Each set of two valves are controlled by one rocker arm, which is operated by the camshaft. Each rocker arm has a slipper follower mounted to the rocker arm with a spring, allowing the slipper follower to move up and down with the high lobe without affecting the rocker arm. When the engine is operating below 6000-7000 rpm (dependent on year, car, and ECU installed), the low lobe is operating the rocker arm and thus the valves. When the engine is operating above the lift engagement point, the ECU activates an oil pressure switch which pushes a sliding pin under the slipper follower on each rocker arm. This in effect, switches to the high lobe causing high lift and longer duration.
The system was first used in 1999 Toyota Celica SS-II with 2ZZ-GE. Toyota has now ceased production of its VVTL-i engines for most markets, because the engine does not meet Euro IV specifications for emissions. As a result, this engine has been discontinued on some Toyota models, including that of the Corolla T-Sport (Europe), Corolla Sportivo (Australia), Celica, Corolla XRS, Toyota Matrix XRS, and the Pontiac Vibe GT, all of which had the 2ZZ-GE engine fitted. The Lotus Elise continues to offer the 2ZZ-GE and the 1ZZ-FE engine, while the Exige offers the engine with a supercharger.
VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles. It was invented by Honda R&D engineer Ikuo Kajitani<sup id="cite_ref-1989vtecengine_0-0" class="reference">[1]</sup>, and was the first system of its kind. Different types of variable valve timing and lift control systems have also been produced by other manufacturers (MIVEC from Mitsubishi, AVCS from Subaru, VVTL-i from Toyota, VarioCam Plus from Porsche, VVC from Rover Group, VVEL from Nissan, etc.).
VTEC was initially designed to increase the power output of an engine to 100 PS/liter or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output. In practice, a fully variable valve timing engine is difficult to design and implement.
Additionally, Japan has a tax on engine displacement, requiring Japanese auto manufacturers to make higher-performing engines with lower displacement. In cars such as the Toyota Supra and Nissan 300ZX, this was accomplished with a turbocharger. In the case of the Mazda RX-7 and RX-8, a rotary engine was used. VTEC serves as yet another method to derive very high specific output (power/unit displacement) from smaller-displacement engines.
The VTEC system is a simple method of endowing the engine with multiple camshaft profiles optimized for low and high RPM operations. Instead of one cam lobe actuating each valve, there are two: one optimized for low-RPM stability & fuel efficiency; the other designed to maximize high-RPM power output. Switching between the two cam lobes is controlled by the ECU which takes account of engine oil pressure, engine temperature, vehicle speed, engine speed and throttle position. Using these inputs, the ECU is programmed to switch from the low lift to the high lift cam lobes when the conditions mean that engine output will be improved. At the switch point a solenoid is actuated which allows oil pressure from a spool valve to operate a locking pin which binds the high RPM cam follower to the low RPM ones. From this point on, the poppet valve opens and closes according to the high-lift profile, which opens the valve further and for a longer time. The switch-over point is variable, between a minimum and maximum point, and is determined by engine load. The switch back from high to low RPM cams is set to occur at a lower engine speed than the up-switch (hysteresis) to avoid a situation in which the engine is asked to operate continuously at or around the switch-over point.
The opposite approach to variable timing is to produce a camshaft which is better suited to high RPM operation. This approach means that the vehicle will run very poorly at low RPM (where most automobiles spend much of their time) and much better at high RPM. VTEC is the result of an effort to marry high RPM performance with low RPM stability.
OR YOU CAN VISIT en.wikipedia.org for more details and exmplaes
