do a compression test on the engine after you set the valve clearances. Then waste absolutely no time with any ustaad pump walay. Remove the pump and injectors, hand them over to Cummins Pakistan on Sh Faisal - next to Awami Markaz. Tell them the car and engine no. note the full first 6 digits of the engine no. it denotes its model and type.
I will post you how I set the timing and it was spot on every single time. Engine with solid basso compression, fresh pump and injectors from Diesel Power systems, engine timed correctly, good engine oil and the engine will fire with a touch on the starter and idle beautifully
Install the factory thermostat - it was 80C on this car, use glysantin G05 coolant (same as MB factory golden coolant) change the gearbox oil, it takes ATF.
That battery you have bought is useless, this little engine requires a manly brute of a battery. The DIN battery is best, its pricey but worth everything spent.
