I have wagon r 2018 model, recently had head cylinder work due to bad valves. After that car has problem of low rpm i.e 550 to 600. And also rattling sound occassionaly from the engine. And one more issue that i am facing after head cylinder work that is smell coming from exhaust, smell is like burnt fuel. No discharge or smoke from the exhaust pipe
Throttle body serviced, no fault code in the scanner as well, no check light, spark plugs checked after 5000km they are also fine.
Discussed with the mechanic he said he cant do anything as throttle body is autmatically adjusting the RPM.
Kindly advise what to do or advise a mechanic in lahore who is expert in his work.
