Which tyre is best other then stock in 13 inch which have road grip and good milage i am an uber driver i have moatly having problem with 145-80-13 please suggest me other tyre size either its 155-80-13165-70-13
165-70-13. You don't compromise you fuel economy that much, your suspension doesn't takes much toll yet you get some road grip.
If the stock tire size is 145/80/R13 then you can max. choose 155mm wider tires only.Choosing 165mm will increase the fuel consumption and may affect air dynamics at higher speeds even a minor effect on speedometer readings too. Also 165mm tires are more prone to punctures.
Chup kar ke stick with company recommended profile. Koi Einsteins help nahi karain ge jab suspension ka kaam nikle ga aur aik lakh ka bill banay ga.
For ride hailing services just stick to the factory tire size. You probably don't need the additional grip. I'm using 175/65 and no major issues with suspension so far. Keep tire pressure at or above 32psi for best feel economy
R u using 175/65 on wagonr and what furl average u have got with it pls.
Yes, I'm getting around 16 with AC. Around 19-20 without ac. This is an fuel average I get with regular driving in the city on light foot. Tire pressure is kept at or above 32psi
