For service intervals and specifications, always refer to your owner's manual. If you do not have the owner's manual OR service history and have recently purchased a second hand vehicle and are unsure as to how to proceed. The following should be of some assistance.
Assuming that you spent your money wisely and thoroughly inspected the car of damage and wear and tear, the following are the approx intervals followed by almost all manufacturers for small passenger vehicles. (Gasoline)
1. Engine Oil & Oil FIlter -Every 5000kms or Three months (whichever comes first)
2.Sparkplugs - (have a life span of 15,000Kms approx)
3.Every 10,000 kms Get an engine tune (Lash/rocker arm type OHV engines only require valve clearance/lash adjustment) Most vehicles like the Corolla & Cultus are fitted with hydraulic bucket tappets and they and are usually the self adjusting type. Always follow OE recommeded clearences and never go +/-.050mm over recommneded clearance. If your valves rap/or lossen before that, you've got faulty valve pins. Its a good idea to have your carburettor cleaned with every tune. Just because someone doesn't know how to do it, dosen't mean its not recommended. Prolonged negligence will see your fuel intake go up due to blocked ancilliaried and buildup aroun the needle valve. (thats another reason, Engineering graduates are held in greater esteem than the Polytechnic diploma holders).
4.Every 10.000kms, get your brakes cleaned and readjusted. That includes your E-brake too. Do not forget to include the rear drum/discs to save moeny. At the service, replace your airfilter as well.
5. Your fuel filter gets the dump at 20,000
5. Change all fluids and lubricants at40,000kms. They are gearbox oil, brake oil,Coolant, powersteering oil and so on. Contrary to what people tell you, these oils are not there for a life time. Don't tisk it.
7. Timing and V-Belts go at 80,000kms if the vehicle is excessivly used for offroad, dusty excursions and 100,000 if used in an Urban environment.
Remember, ALWAYS REPLACE used o-rings and gaskets with new ones. Older ones should never be reused. If your vehicle overheats, replace engine oil as soon as possible while getting the problem rectified.
