I have a Cuore 2000. Yesterday while I was driving around with AC turned on for quite a while. I noticed that water started dripping from the condenser/Compressor or wahtever it is underneath the dashbord in front of the passanger seat? I don't think this is normal, or is it? What should I do?
NOT A MAJOR ISSUE. THE PIPE MUST HAVE SLIPPED OFF... THIS HAPPENED IN MY CULTUS N I PUT IT BACK ON MYSELF...
@xonoNot a big issue at all. Keep your car start and AC on and than remove the floor carpet underneath the dashboard. u will see a black pipe, or if you dont see it, try to check the leakage with your hand. its just a rubber pipe that might have developed some cracks or have slipped off. Same thing happened with my khyber last week.
Thanks deel_ee & mad_racer for your help. The pipe had slipped just as you said. I've put it back on.
at first i thought that roof is leaking.
its a minor fault in cultus
guys i am having same issue with city 04
after spending 20,000 on AC ,,,, water is dripping inside
AC technician says that the duck inside is faulty ......he tried to fix it up with j'ogar' week ago but yesterday its start again
the drain pipe extending from evaporator inside the cabin towards engine bay is clogged, use gun brush or an old tooth brush with extended stick from engine bay side to clean that problem will be solved.
I have mehran vxr euro and have the same problem of water dripping inside the passanger compartment. The drain pipe is at its place but the water is dripping from a fitting under dashboard left side. Seems its coming from a white colourd duct passing under dashboard. Pls anyone guide me
