Dear PWs
I bought suzuki khyber 1994 Model 3 days ago. Its engine was releasing smoke so i got it checked. The mechanic told me that its 'rings' are worn out. So he replaced them with new. And also replaced the old gasket with new one.
When i bought the car, the seller told me that its AC only needs gas refilling. Since i am not very expert in technical things so i trusted him. Today i went to the AC guy. He told me that the blower is not working (which is true), and its Jaali (probably condensor) needs to be replaced. Further he said, the compressor already installed in it is bigger in size so when it is ON, it might break the foundation with its continuous vibration. But he says, he wi do some 'juggad' for the conpressor (if compressor is otherwise working fine). Total expense which he told me was 10k (without compressor) and 17k-20k (with compressor).
At this point, money may not be an issue. But my concern is that i have heard that old cars sometimes face issue of 'heat-ups' when their AC is switched on. I dont want that i face this issue even after spending around 20k on AC.
The AC guys says that i cannon predict if the car will have heat up issues after AC is made functional. This confuses me more.
You guys are requested to guide me in this regard.
(I live in karachi). Thanks in advance.
