Yes i did. Apparently the dholki was broken from inside. So the mesh inside the dholki was broken, as a result the noise came only after 3000rpm. I got it fixed and the noise went away. Acceleration, economy and noise all were better after as well. So that was the root cause
Do get the dholki checked, if thats okay then there will be a leak in the exhaust pipe. Get that checked as well.
Suzuki dealership is the most incompetent group of mechanics i have ever met, so no point in going to them.
