Dear members.When I turn on the ac of my passo 2009 model there is weird heavy sound from the front side. Don't know what will be the issue. Sound come with acceleration without ac there is no sound any suggestion.
Check inner side axles of both sides
Could be the Ac compressor....last same happened with my mira
If the problem is axels then there should be sound without ac as well. Right ?
U mean when u turn on the ac then sound comes?
Yes when car is running on ac then sound comes. Otherwise there is no sound.
Get the fitment of compressor checked.It may be some bolt loose it causing this noise
