AoA,I feel some odd wobble near rear left wheel or maybe front wheel but i feel like my vitz 2003 is bent in corners.i feel this during the speed from 1-10km/hr and steering wheel vibr after 100.The mechanic changed the chimptas,steering box,tyres & rims that maybe bend but no luck.Pl suggest me what to do.im in peshawar
whats "chimtas"
I think he is referring to the wheel hubs, or lower control arm
Control arm, it's called a chimta or a kenchi now. Get with the times bro.
Chimtas - lower control armsMechanics logics are out of world.
Ive been a mechanic for decades - never called it a damn chimta, its always been a control arm - and for illterate idiots selling scrap as parts I called it qenchi (scissors).
BUT
we are not illterate idiots on PW
sounds like your tires have shifted belts inside
Pl explain , how? With solution.tnx in adv
Lol. There's also ribban palish, goday, raakit clip, vaashal, samosa and many more.
oh yes - lots of them, makhi, chaat rubber, chaabri, taanay, towray, kaablay,
lots of them, I dont repeat them though.
Engine ki kursi ENGINE MOUNTS
Suluf - selfPvc valve - blow val
Welcome.again to the legends B**shi*t
Guys pl concentrate on my problem.No one is suggesting what to do
Welcome to Pakwheels..this is normal here.When you ask for your problem, either you will become center of joke or your car will. That's how it works I guess. Please check stabilizing links, commonly called as z links or andy. Also check axles and its boots.Lift car on jack. Give jerks to wheels with hands. If you find any free movement then there is some problem. Find the thing that is moving. Replace it.
one needs to install a "sarcasm decoder" in brain to avoid getting offended by his posts.
Have you checked your tires for shifted belts? Do you have another car whose tires you can install?
Are the control arm bushings worn out?
Or you missed that post?
what happened to the posts?
