no as far as i m concerned i haven't seen any of them ,i was using shell helix plus at that time and the stated mileage was 5000km , i didn't check my engine oil so often ,so luckily one day i just happened to check my engine oil at 4400km and the oil was reduced .
I m really confused now because the engine seems to be fine as no smoke release,no vibration,no starting problem,car starts usually on first or second sulf(sorry i dont know the right spellings of this bold word so bear it with me n i hope you understood), there is no oil leakage atleast apparently ,
Even my friend checked my car and said the engine is fine ,there may be something wrong with the quality of oil which resulted in reduction so i m confused
Yeah one thing there was a problem in current supply to the plugs because of carbon( mechanic told me this that there was carbon on the point due to which current was not flowing smoothly to plugs as a result there was lot of missing and engine was vibrating and i had to push accelerator hard to avoid that missing thingy) due to which the plugs were sparking also the plugs were quite old (and now i have replaced them with new plugs ) does this have any effect on oil reduction?
