I don't use car regularly, only on long routes hence the reason for 15K.
This is what my middle cylinder valve looks like, mine one is a little darker (taken from google)
So question in my mind is how can a valve be burnt @ only 15,000 Km driven car, my mechanic says its either due to bad fuel (chemical wala fuel) and that chemical forms on valve and starts to burn (but then why just on one valve and not all of them) and the other reason he given that it can happen w/o any reason and piston/rings/valves is made of metal and metal can break at anytime. The thing is how can even "chemical" of bad fuel formed on valve since its very less driven car. Mostly its just stays park in the garage.
Cylinder had zero compression when checked with gauge and the spark plug was also burnt.
Thanks for helping.
