I have cultus EFI 2011.
I had no idea what engine oil grade previous owner was using so I mistakenly poured 4 litre 10w-30 engine oil after which car started to produce gray and bluish smoke during cold start. I had reduced the oil level to 3.5 litres after noticing the mistake.
I drove around 1500 km and there was no oil or coolant level reduction.
Had to go for valve seals replacement due to smoke issue. Changed head gasket along with head facing. Mechanic suggested to use 20w-50 after valve seals replacement. There is no smoke now but I am not satisfied with 20w-50 as milage has dropped.
I am now planning to use 10w-30 or 10w-40.
Please advise which oil grade i should use after valve seals replacement as I don't want to use 20w-50.
Thanks
